Budget boost to coil lift
If I have a teraflex budget boost on my jeep right now can I just swap the stock coils and spacers for 2.5 inch coils? Would I be able to go with 3 inches?
Its almost the same just 1/2" higher. If you installed the rear sway bar drop down bracket and shock extenders with the budge boost then you'll be fine. Maybe bumpstop spacer and longer front sway bar links or extensions? You may also need brake line extension brackets. All the above are pretty cheap if you don't have them already.
I'm doing the same thing, going from a BB to a full lift, but I'm doing the coils last. I did tie rod, extended discos, and front adjustable track bar, next is rear track bar, lower CAs, drag link, and brake lines. That way I know when I throw the coils in, I'll know everything is going to work well. Don't rush it, you could add coils(which generally give you more lift then they advertise) and wear out a lot of stuff that will cause DW and end up costing you more. Do the transition in stages. Switch everything to adjustable so once you go taller you can dial in you steering again. You might buy 3 inch coils, and end up getting 4+ inches of lift until they settle. Without being to adjust LCAs or track bars, that would make or one terrible ride.
You can also get aev front lower control arm drop down bracket for $99. It does exactly what an adjustable control arm does and UT would be better to keep the factory arms due to them lasting longer. Unless you upgrade to a longarm, save the money and keep them.
Former Vendor
To OP, go with the 3" coils... See what you think, if it's too 'flighty' swap out those front lower CA's (reccomended adjustable).
be very careful how high you go on a 2door with stock driveshafts, anything over 3" and some lifts at 3" need front and rear shafts or bad things can happen.
^Not necessarily, it makes the control arm fixed. Having adjustables allow you to properly dial in your castor depending on lift yeild; heavier bumpers and winches throw your geometry off as well.
