Budget Boost
#22
This is a next to stock JK suspension wise. Has 16/58 coils, JKS quicker disconnects and bilstein shocks.. (mango flexing)
Mine is the red JKU with 18/59, rubi shocks, quicker discos and TF 2.5" BB
#23
You will only need to relocate your brake lines/rear and will need longer sway bar links in the front. You can get quick disconnects or use the rear sway bar links on the front and score another pair of rear sway bar links for rear. If you do the 2.5" BB with 18/59 or 19/60 coils, you are going to net closer to 3-3.5" of lift. And all the above stuff I mentioned WILL be needed...
#24
Originally Posted by mark jk
Rubicon springs . And No kit . I said it wrong . will i steel need all of the relocaters and things ? Thanks
#26
First up is just 16/55s, then is 16/55s and TF 2.5bb (explains why the back is a little low), finally is just 16/58s. Same tires in all pics.
And the photo Battlefrog posted earlier is with my Bilsteins and the same 16/58s.
#27
#29
Rubicon springs only. Thanks I will look for some.
#30
so in other words, after the stiffer springs making up for what you lost from weight you are now 1/4 '' over stock height?. I just did the leveling kit a couple weeks ago , my bumper/winch is heavy i wish i would have got a 2.5 '' puck for the front because with the lift the rear will still be 1/2'' higher than the front because of the weight.
I think I'm sitting pretty much level without any leveling kit.
