Broken front track bar bracket
Old 06-23-2008 | 06:52 AM
slimedcj's Avatar
Default Broken front track bar bracket
Ok so does anyone know of a repair or replacement part to fix a broken off front trac bar bracket off the axle housing.
Bmo
Old 06-23-2008 | 07:09 AM
slimedcj's Avatar
Normal mig welder work or need some special welder.
Tia.
Bmo
Old 06-23-2008 | 07:34 AM
wayoflife's Avatar
JK-Forum Founder
so long as you are getting things welded on, i would recommend that you upgrade to one of these...
Currie Rock Jock FRONT TRAC BAR RELOCATOR KIT FROM JK OFF ROAD SUSPENSION KIT
Old 06-23-2008 | 08:07 AM
slimedcj's Avatar
How does this one caompare to the BDS bracket. that's what we put on it with the stock trac bar.
I was thinking about putting the bracket back on and just using an adjustable trac bar and the skyjacker brace.
Any thoughts on that set up????
TIA
Bmo
Old 06-23-2008 | 08:12 AM
wayoflife's Avatar
JK-Forum Founder
i haven't installed or seen a bds bracket up close but i can tell you that the currie rock jock setup, is as beefy as can be. here's a couple of shots of what it looks like installed....
Old 06-23-2008 | 11:18 AM
slimedcj's Avatar
Thanks for the info and the pic's ordered one up today.
Bmo
