Broken Body Bolt! Any Help!?
Okay this is what you have.. I am smacking my self in the head.. you are going to have to follow the body lift instructions in the link I gave you and lift one side of your body up.. you will have to remove that mount and replace it with a new one.. the mount looks like the black ones in this picture.. the replace the front ones .. but; the side are the same just shorter.. I replaced all of mine a few weeks ago when I added by body lift.. bummer.. I threw them away I could have mailed you one..
Order a new mount from Jeep ... It's not a very difficult job.. follow the directions in the link.. until you are able to remove that one peice.. then replace it with the new one..
Thank you so much for your help man, you have no idea how much I appreciate it. This is my new baby (only had it for 2.5 weeks, 900 on the odometer) and I was freaking out a little bit when that happened. You're definitely making me feel better haha
Okay follow along with me here.. When I added my body lift I had to reuse the stock mounts.. I had to punch out the old bolts and then add the spacer and use the longer provided nuts & bolts.. so you can remove that bolt and replace it with another hight strength bolt right from a hardware store..
Use a center punch and pound it right up.. you may want to put some pb blaster on it first.. it will come out.. if you can't get it out.. then pull the mount and then beat it out and put a new bolt in...
Damn what was I thinking .. I must be tired or old age is gotten to me.. why would I forget that..
the bolts in the isolator that goes bolted to the chassis are just pressed in. Take the isolation out, and with a bench vice you can press them out. very easy to do. When installing a body lift you have to remove these and use the longer bolts supplied with the kit. I installed a body lift a while back, and the bolts you are talking about were easy out to pop out. I would say if you had a box ended wrench big enough fit around the head of the bolt ( to support it on a bench so you don't bend the tab on the isolator) and hit it with a dirty big hammer, you could hammer them out.
Ah, you're right. So I've been trying to hammer that sucker out from the bottom so i wouldn't need to lift up the body but it's not working. I guess I'll pull the entire mount out by lifting the body up and then smack that sucker out and replace it. I am wondering though, because I know I over-torqued the other bolts on the other 3 mounts I touched, if I should just buy new mounts all together (with screws and bolts in place) and replace them all at once.
Yeah, that sounds like a good course of action. I'm thinking I may do a M.O.R.E. body lift at the same time as I'll have to pull everything anyway and it attaches on the top (so it wont interfere with the sliders i threw on that bolt on those bolts). Do you think that would be an issue at all? The sliders mount up from below on those 2 smaller bolts and the MORE lift would be on top of that center bolt?
FIXED. Whew.
YES - I got the bolt knocked out from the bottom up. Here is the source of my heartache:
It took me, my father-in-law, and his good buddy about 3 hours to work this POS out. In the end, I didn't have to lift the body off at all.
What. A. Nightmare. Lesson learned.
Thank you echo, remark, and coby dick for helping me out with this. I was losing my mind.
Pressed-in?......Press-out!
Next time try jacking the Jeep up a small amount. Place a center punch on the sheared bolt. Support the punch from the ground up. Carefully lower the jack and hopefully the weight of the Jeep will force the bolt out. Conversely, You could use the jack to support the center punch; and jack the punch up to force the bolt out. Probably much safer that way. Adding a little heat from a propane torch probably wouldn't hurt either. Just make sure that you don't jack the Jeep so high that when the bolt releases; the punch point doesn't end up driving through your Jeep's floor.
My $0.02. Glad you got it out!
I'm still bummed this happened at all, but definitely a lesson learned. Thanks for all the feedback, I love this forum.
