Broke a Brake line
Broke a Brake line
Well I accidentaly broke a brake line. It broke where the hard line meets the soft line. It broke off right at the head where they come together. I really have no idea what to do. I don't mess with brakes. Any help would be appreciated. If I need to post a picture I can.
Time to upgrade to a set of stainless steel lines
http://www.northridge4x4.com/proddet...rod=CROWN-JK-F
David
Edit: after re-reading your post did you brake the hard line that runs the length of your frame?
David
David
David
Not good!
I had the same thing happen to me this past weeken d on the trail. I borrowed this pic from another thread to show where it broke.
The break happened on the black steel side of the line right at the fitting...
[/QUOTE]
Anyone have a quick fix?
[/QUOTE]
you can get brake line in various lengths with fittings and flared ends already. this is if you don't feel comfortable flaring it yourself. just follow the line back to the next fitting, measure the length, install new and bleed system. don't let the reservoir go dry by the way
