Brink Fab Cage Built-Up on 4 Door JK
Old 04-28-2008 | 02:17 PM
  #31
JK-Boy's Avatar
Originally Posted by putnam dan
Simple - pad the bars near your head. There is a big risk of a skull fracture with exposed roll cage bars coming into contact with your head.
what would u use for padding?
Old 04-28-2008 | 03:25 PM
  #32
2K1TJ's Avatar
Go to summitracing(dotcom) and do a search for roll cage padding.
Old 04-28-2008 | 10:55 PM
  #33
JK-Boy's Avatar
here's the windshield pictures and 90% of completed cage
ID:	8479   Click image for larger version
ID:	8480   Click image for larger version
ID:	8481   Click image for larger version
ID:	8482   Click image for larger version
Old 04-28-2008 | 11:00 PM
  #34
JK-Boy's Avatar
right now it's just tacked in place, getting it full welded on wednesday, also adding plate steel on top of the two parallel bars, front and back, for CB, Sat, etc.
Each entry side will have another bent tube welded on, as a handle.
Racing seats and 5 point harness will go in on thur or fri.
After I get 1" body lift, we'll weld the cage to the frame
I LOVE IT
ID:	8484   Click image for larger version
ID:	8485   Click image for larger version
ID:	8486   Click image for larger version
Old 04-28-2008 | 11:37 PM
  #35
2K1TJ's Avatar
Thanks for posting more pics. I was hoping you were going through the dash with this.
What size tubing did you use, and how much have you used so far?
Old 04-29-2008 | 06:29 AM
  #36
Rubicon Rando's Avatar
looks good man
x2 on what tubing you used and how much
Old 04-29-2008 | 07:12 AM
  #37
HUNTER's Avatar
Kick ass cage!
One question though. I know you mentioned keeping the hard top crossbar mounts but did you look into remove/replace the down tubes it bolts too(think its tied into the door jamb)? Reason I ask is that you put another down tube right behind the front seats pretty much in the rear door opening.
Did you do this as you went along or do you have a schetches/drawings/blue prints.\? I am planning on a half cab and eliminating the rear cage all together. Thanks in advance for the ideas.
Old 04-29-2008 | 07:51 AM
  #38
RedneckJeep's Avatar
If black is good enough for you, go to Lowes and get some PVC pipe insulation. Way cheaper than the Summit stuff. Comes in like 8' lengths. You can fasten it on with black zip ties. Comes in most popular diameters. By the way, I've been welding longer than a lot of you are old and still get certified every year even though I don't do very much anymore. I gotta say, it's a damn good lookin job.
Old 04-29-2008 | 09:27 PM
  #39
JK-Boy's Avatar
Originally Posted by Rubicon Rando
looks good man
Thanks
1.5" .125 Wall DOM Pipe
I don't know how much, havent measure it :P
It sure catches peoples eyes on the roads
Old 04-29-2008 | 09:30 PM
  #40
JK-Boy's Avatar
Originally Posted by HUNTER
Kick ass cage!
it doesnt bolt into a tube, i'll check tomorrow but it looked weak so it had to be reinforced?
blueprints?
Quick Reply: Brink Fab Cage Built-Up on 4 Door JK
