Brakes with beadlock
Which brakes do you use with beadlock wheels and larger tires (37-40)? Any feedback? If you were to do it again, would you go the same way?
I'm running the Teraflex big brake kit with upgraded master cylinder and I love the stopping power as well the holding strength while winching another vehicle. Very good system quality upgrade IMO.
^^^ +1
I'm using the same Teraflex Big Brake kit with their master cylinder and it is significantly better than stock. The only thing with pushing more brake fluid to the two piston calipers is that the brake pedal will feel softer than stock. It doesn't take much time to get use to it though.
