brake upgrade?
Old 01-28-2008 | 10:02 AM
  #21
jsmoriss's Avatar
Originally Posted by Heavyd17
I just got some info from Burnsville offroad that they are working on a brake upgrade with Mopar develop a big brake for the front using Chrysler Aspen brakes. Will be a couple months before they will start selling them.
The current brakes barely fit within 15" wheels. I hope they'll keep in mind those of us bucking the trend for bigger wheels (I sized down from 17" to 16").
js.
Old 01-28-2008 | 05:16 PM
  #22
ralfs56's Avatar
js.
Fat chance. It's just by pure luck that some 15" wheels fit. What do you do when that stubborn bolt won't come loose (fire wrench not allowed)?. You grab the big breaker bar for more LEVERAGE.
You want better, more effective brakes, you've got to use a bigger diameter rotor.
Yeah, some will claim hydroboost or more agressive pads. But that's like putting a band aide on it. A caliper must be designed for hydroboost. The higher pressures in a caliper not designed for it can lead to more flex in the caliper and strange wear patterns on the linings. In some situations stopping distance could suffer. More agressive pads are an option, but the tradeoff could be noise, dust, and brake roughness (warping to the uneducated).
If you haven't noticed, all manufacturers are going to bigger wheels and bigger brakes. Vehicles are getting heavier. Stopping distance requirements are getting tougher. To meet all this, bigger base brake systems are required. 15" wheels are history, 16"'s aren't far behind.
Old 03-19-2008 | 07:50 AM
  #23
avosfit's Avatar
Default Rotors
I just found something interesting. I finally found someone that is selling a real brake upgrade that isn't $10K but isn't cheep either.
http://brakeperformance.com
approx $350 to $450 for a complete (4 rotor) set.
It is pricey for a rotor upgrade but if someone can't wait for more companies to throw there hat in the ring - here you go.
Does anyone know:
what other Jeep's have the same size front/ rear rotors???
for instance Honda uses the same rotors on a LOT of there CIVICS from the mid 90's and they will are the same size and the rotors on the new '07 Honda FIt.
Old 03-26-2008 | 04:04 PM
  #24
ralfs56's Avatar
Does anyone know:
JK rotors are unique to JK.
Wouldn't it be nice to see some performance data from these companies that sell drilled and slotted rotors???? They sure want you to spend a lot of $$$ based on some vague claims. Maybe there's a reason they don't publish any.
Old 03-18-2009 | 09:04 PM
  #25
JK09's Avatar
Originally Posted by JJK
EBC is producing Yellowstuff pads at the moment for the JK. Will be available early Jan.
Green and greenstuff are vailable now, as are rear rotors with slots
Quick Reply: brake upgrade?
