Brake Rotors
Brake Rotors
The rear brakes on my 08 JK needs replacing. Any thoughts on going with drilled & slotted rotors or should I stick with OEM rotors. Also ceramic or semi-mettalic pads?
Thanks in advance
Thanks in advance
How long do you plan on keeping it? Do you tow trailers? My opinion- drilled and slotted with ceramic pads. Ebc pads would be a good place to look too......
Do you do any wheeling? Only reason I ask is if you go through muddy water, some sludge could get stuck in the drilled rotors before you have a chance to clean them. I think slotted rotors would be morenthan sufficient with a better pad. And it would save a little bit of money
