brake line smooshed...
#21
Ripped out my right rear in Moab this year and after crimping the hard line as best I could I still couldn't stop it from dripping completely and can confirm my experience was the same that you have zero brakes at that point. My e-brake works pretty good and the combo of that and downshifting the auto I got home without issue.
#22
How do they do that when there's typically only one line that splits into two near the rear axle that feeds both rear brakes?
Edit: I guess with some modern ABS systems, each rear wheel has it's own feed. And diagonally, you would need two proportioning valves.
#23
No. Abs is sensed on a wheel by wheel basis but when actuated it is just one motor driven on off rapidily pulsating on/off valve in the fluid line that helps any wheel from locking up in a panic stop situation. It works like pumping the brakes at 600 times per minute.
#24
#25
I don't see how the brake lock differential would work with a single on/off valve, I think you would need a valve for each wheel. Other ABS systems may work as you described, but I believe the JK system has a the ability to control a single wheel at a time, whether for traction or for ABS.
Not saying I couldn't be wrong.
#26
https://www.youtube.com/watch?v=UUUbPo9pY1E https://www.youtube.com/watch?v=IKi5O3ZlSu4
#27
So it seems like the only way to prevent this from happening is to swap out the master cylinder with a type with two individual reservoirs to not loose all of the fluid. That's only if this type would work with modern ABS systems.
