brake line smooshed...
Old 08-27-2015 | 06:16 AM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
Originally Posted by kbiv
Are you sure about the diagonal split? I thought it was split front/rear. I can't imagine trying to stop with only one front brake working, it would either force you into oncoming traffic or into a ditch.
My experience is they are split diagonally most of the time.
Old 08-27-2015 | 09:56 AM
lulu2533's Avatar
As long as I have some brakes. That is all I care about.
Ordered new brake lines from Northridge this morning so hopefully by next weekend they will get installed.
Old 08-27-2015 | 09:58 AM
lulu2533's Avatar
One more question...since I ordered the same brake lines that I had on, can I just install the one or should I install both rears?
Old 08-27-2015 | 10:58 AM
Since the other one is good, just replace and bleed the bad side. No need to double your effort.
Old 08-27-2015 | 05:56 PM
lulu2533's Avatar
Thanks Mark
Old 08-30-2015 | 06:41 PM
kmrtnsn's Avatar
You completely misunderstand the operation of hydraulic brakes. If there is a break in a closed hydraulic system the entire system is compromised. Not just a particular corner of a vehicle, as you suppose. Last year I broke a brake line at Moab on the left rear corner. All of my Jeep's braking function was compromised until I could replace that one line.
Old 08-31-2015 | 02:20 AM
Hmm. You should have only last half the brakes. At least that's how most vehicle braking systems work. Can't believe Jeep would change that--I always assumed it was federal law ...
"A typical master cylinder is actually two completely separate master cylinders in one housing, each handling two wheels. This way if one side fails, you will still be able to stop the car. The brake warning light on the dash will light if either side fails, alerting you to the problem."
Automobile Brakes - A Short Course on How They Work | CarParts.com
Old 08-31-2015 | 12:28 PM
pvanweelden's Avatar
In theory, that is how it is supposed to work, but it doesn't seem to work that way after you lose the fluid.
I just had the unfortunate pleasure of losing my 2 caliper bolts, which was followed by the pads falling off and the piston, all in the middle of nowhere Nebraska on my way to Denver. Friday night, only auto parts store didn't reopen until Monday. So I pinched the hard line, topped off fluid, thinking I would still have some brakes, but there was nothing. I only
had engine brake and the awesome jk e brake :(
maybe if I had bled the other corners?
Since then I bought a cap for the hardline fitting, so I could cap it off, bleeding it with the cap. And I used a paint pen on the caliper bolts so I visually tell if they come loose
Old 08-31-2015 | 12:32 PM
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=623331"/>
Well, darned. My e-brake does nothing. If I don't park in gear, the Jeep will roll into the street ... because my driveway is so steep (not!).
Old 08-31-2015 | 12:46 PM
I was being sarcastic when I said awesome jk e brake mine does nothing, so thank god I had a manual!
