Brake line relocated????
Did the same thing to mine, as have a few others on here. Every single one that I've seen was running the TF 2.5" coil lift and it was always the rear passenger side. Did you recenter the rear axle after the lift? I didn't, and I'm trying to figure out if that may have something to do with it. Mine got pulled down just like yours while wheeling, then caught again later and pushed back up. Never split the line. My brakes still work fine. Take a hacksaw and cut all the extra bolt off the swaybar link stud.
Here's another thread on the subject:
https://www.jk-forum.com/forums/show...-to-replace-it
Wow, that's the first drivers side line that I remember reading about. I guess I can throw the uncentered rear axle theory out the window. And yes, I am still using that same brake line. I have it zip-tied to the frame rail to keep it out of harms way. I know it's not the smartest move, so I am in no way suggesting this solution to you. Some day when I have some extra cash, I really do plan on getting it fixed correctly.
Oh btw - yup, same lift, same problem. teraflex 2.5 coil lift. '07 2 door. Still love the lift, this should have been should have been thought out better though.
It's not too hard to splice the brake line. Just slippery from the brake fluid. You do need a flanging tool(finding that could be that hardest part.).
When I put my lift on my JKU we took a tube bender and relocated the path of the stock hard line and clip that holds the line agains the body.
