Brake line extension for 2011s?
Old 02-11-2011, 11:53 AM
stevedolce's Avatar
Default Brake line extension for 2011s?
i've only found crowns that work on 07-10s. will they fit on 2011s?
if not, what are people doing?
Old 02-11-2011, 11:54 AM
highoctane's Avatar
The axles and suspension have not changed, they should work.
Old 02-11-2011, 11:57 AM
GreenJK07's Avatar
As far as I know they should work on all jk models.
Old 02-11-2011, 02:49 PM
RevyJKU08's Avatar
Get 4 brackets similar to this to extend your brake-lines. I did something similar to this on my JKU with OME HD coilspring lift on all 4 corners. Way cheaper. Cost me like $10 to extend all 4 lines.
Old 02-11-2011, 07:34 PM
stevedolce's Avatar
Default hmm
ok--when looking at my front end, it looked like the brake lines had a bracket attachng them to the jeep. maybe need to take some pix tomorrow..
Old 02-11-2011, 09:10 PM
tangomike3's Avatar
The Crowns do work on 2011. I have them on mine.
Old 02-12-2011, 04:25 PM
stevedolce's Avatar
Default what about the fronts?
my concern is on the fronts..
the brake line is attached with some sorta bracket..
what did ya do?
Old 02-12-2011, 04:59 PM
Sponsoring Vendor
Northridge4x4's Avatar
Just take that bracket off crown lines work great
Old 02-12-2011, 05:55 PM
RLW007's Avatar
I agree. I took those wierd brackets on the 2011 fronts off and replaced them with crowns from Northridge.
Old 02-13-2011, 02:07 PM
HornetJK's Avatar
I still think on the rear it will bring the brake line down even farther and you may have the same issue as before with the brake line braking. As the brake line is pulled down the part of the frame also pushes the brakeline out away from the frame making it more suseptable to getting snagged by the swaybar link. Dave, (NORTHRIDGE) said they are coming up with a fix for the for the swaybar links. We have to find a solution for that prior to EJS.
The front brake line drop brackets will cause the brake line to rub the front shock mount.
Quick Reply: Brake line extension for 2011s?
