Brake line brackets with 2.5" lift?
Do I need front brake line relocation brackets with a 2.5" lift? I have a Rubi, and I'm affraid to use the e-discos...
If yes, where can I buy brake line relocation brackets?
If it turns out that you do need them, you can make them easily from hardware store parts.
https://www.jk-forum.com/forums/modified-jk-tech-2/can-i-see-your-home-made-brake-line-extensions-91799/
With the OME 2.5" lift, the rear were stretched to the max at full drop. Actually keeping the axle from dropping further . Wayoflife is probably correct for the front (I did not verify) but you will run into issues with the rear.
