Brake Force Distributor in ESP?
Does anyone know if he brake force distributor is in the esp set up? I am looking in a few diagrams but am unsure. Reason I ask is I am looking to remove my esp control box completely and tee the fittings together as needed but dont want to lose he front/rear ratio.
I believe if you remove the HCU, you will lose the front/rear ratio. From what I can tell, there is no separate proportioning valve in the system like there was years ago.
Yes sir mine is labeled esp and has if i recall correctly 6 lines. I want to remove that as its in my way, but didn't want to lose the ratio. I guess i may have to relocate it and redo some lines possibly.
I appreciate your help.
Another question. If i remove this it looks like i will have some dash lights as there a plug or 2 on there id have um plugged. Has anyone removed this? If not and your running just rear wheel speed sensors do you leave esp fully disabled? I may try it and am hoping worst case scenario its just the esp light.
