brake/abs line routing help
i just installed 3" teraflex lift. I noticed today my tires rub the abs line and brake lines at full lock.( FRONT OF JEEP)But if you tuck them away, there is not enough slack under full flex. I have the brake lines bolted on the caliper with the line running towards the back of the jeep. I was told to zip them up but the slack under flex makes me nervous. Any help or pics of your setups would be great. Pics would be best.
nobody? wow first time i ever got that. looked at it closer tonight and i just am not sure how to do this. Nothing to zip together and the lines are pretty long. Im also scared a branch will rip them off. the loop goes all the way over my lower control arm on flat groung
I put extended lines on mine and I noticed the same rubbing at full lock. The outer plastic coating was already rubbed through on one side. I couldnt figure out a good way to tie them off either; so I just split some rubber fuel line I had laying around and zip tied it to the brake line. I figured this would at least prevent any more wear from my tire. When I was at the PA Jeeps show in york I checked out Claytons jeep and their lines werent tied off to anything either, I didnt really look for any rub marks though
TeraFlex brake lines seem to be rubbing tires!
I just installed my TeraFlex extended lines that came with my FullFlex 3" this week, and now as I'm getting ready to head out the door I notice that they're rubbing on my tires, too. SH#T. Can't really see a good way to get them out of the way. They're installed with the lines pointed to the rear from the caliper... Anyone have any ideas?
Thanks!
Thanks!
