Bov on ripp supercharger stopped working again!!!!
#51
My Vortech was doing exactly the same thing at 5000 RPM, but I contacted someone very familiar with SC'd JKs and was told that that was a safety feature to ensure the engine isn't over-boosted as it approaches red-line. Maybe prior to switching back to the Vortech, I'll go take a spin to see what happens with the Kayser diverter at that RPM level.
#52
I have used the plastic Vortech and the $40 Bosch from 6-15psi on an FBody in Tennessee, with headers! I never had any problems until the Vortech unit failed, it was 10 years old. I'm surprised you're having issues, I'd thought along RIPP's lines and wondered if you had a vacuum line plumbed right off the intake?
#53
Ok - just got back from a little road excursion and no issue at all boosting past 5k RPM with the Kayser diverter. Reached 9 psi of boost before getting close to 6k RPM. Will re-test with the Vortech BOV later this week.
BOV is plumbed off of the vacuum line leading to the Evap valve just behind the throttle body.
#54
Chuck, did you buy the Turbosmart BOV dual port 25mm that Red mentioned? If so, did that help your boost issues?
#55
If you go back to page 4 of this thread you will see how his BOV attaches. I did not notice that when the discussuion began.
#56
I did buy the Turbosmart bOV but I have a problem. Seems Ripp must have changed the intercooler piping. REDJEEPJK has a different BOV mounting setup. Mine and probably yours has a two bolt flange where you secure the BOV. His has a round hose neck type mount. The Turbosmart BOV requires a round hose neck attaching point. I either need to find an adapter that will convert my two bolt flange to a round hose neck or replace the intercooler piping. I have not figured out how I want to approach this.
#58
The Vortec Maxflow® Racing Bypass/Blow-off Valve that originally came with the RIPP kit.
[/QUOTE]
When you removed the original Blow-off valve and hose, what did you use to plug the port (hole) on the supercharger where the hose connected to it?
[/QUOTE]
#59
#60
