bolt-on front track bar bracket?
Old 12-20-2011, 03:11 PM
road_king's Avatar
There are a couple of bolt on front trackbar braces -- for the frame side. I take it you are looking for a bolt on brace for the axle side.
The bolt in frame brace and/or a weld on axle mount do not require a flip or drop pitmon - both from JKS.
Old 12-20-2011, 03:21 PM
Manvan's Avatar
Skyjacker has a bracket that goes from the trackbar bracket over to a few of the dif cover bolts. I have not used it on the front but my lift uses one similar to this on the back.
Old 12-20-2011, 05:22 PM
PartySnake's Avatar
Originally Posted by runnin-low
ok so after reading some more..the only way i can get away with re-enforcing the track bar bracket is if i flip the pitman arm. and then get a new relocation bracket. ah! i guess ill do more research and see what how i should work this.
I really like this peice made by full traction. I would like to get this when the money is right.
https://www.jk-forum.com/forums/show...tion+track+bar
Quick Reply: bolt-on front track bar bracket?
