Body Lifting
Body Lifting
when doing a 1" body lift w/ a suspension lift or a BB do i need to worry about shock length or relocation other then what i already do when doing the suspension? or is that a compleatly seperate area of the jeep?
friday i put the pro comp 1.75" coil spacers on with the 1" front spacer (to remove the rake) and i also have a 1" m.o.r.e body lift, no problems yeat i have driven about 200mi
Eternal ***erator
Adding a body lift has zero effect on the suspension, your raising the body up off the frame. So no effect on the shocks there.
If your adding a budget boost, i would simply say to follow the recomendations of the mfg.
Some BB come with shocks, some with shock extenders. The real area of concern if you left the stock shocks on is at full extension, the shocks will top out before the suspension gets to full flex.
I added a 2" BB and shocks at the same time. I was at the time driving a lot of washbaord type dirt roads, and the stock shocks just ended up squating or loading up however you want to say it (and probably got kinda warm from a lot of constant use over a short period of time.) They just plain old didnt work right, so i changed them for monotubes & couldnt be happier with them.
