Body Lift v Coil Spacers????
ok heres a quick rundown on what I have. 2009 Unlimited X. Lift installed at the dealership in Texas. Im pretty sure its a 2.5'' lift. Being a student it works out nicely that its all under warranty, but the jeep rides a little poorly.
I am just planning on running the lowest lift possible with 37's. (i have 35's now). I know they pretty much do the same in regards to having a low center of gravity.
Now I have a 1" BL. I am having the normal problems with it, inner shock boot is interfering with the 6-speed stick, and a somewhat unsightly space between tailgate and rear bumper. And maybe im crazy, but I feel as if there is a difference in the ride quality. I know I can cut the inner shock boot or take a torch and bend the shifter, but I would rather not.
So I was wondering if taking off the BL and running the Coil Spacers will make a difference in the ride quality. There are obviously many different spacers. Some plastic, some metal, 1" to 2". I have looked at alot of them, any preference?
Also I am about to purchase a new front bumper and Im wondering if the BL lift will cause the bumper to look a little weird. Does anyone have this problem?
thanks for the help.
If the coil spacers have any effect on your ride quality, it will be to make the ride and handling worse, not better. Adding coil spacers will move your control arms further away from being horizontal, which will make the ride feel worse.
