Body Armor Extreme rails/bumpers
I have the front and rear bumpers. The rear also has the swing-out tire carrier.
Made from 3/16" steel. They look good, and appear to function well. Sorry, no pics, but there are several at the Body Armor web site.
Body Armor did a re-design on their rear bumper system. The older swing-out tire carrier (JK-2393 bumper and 5292) had a few problems with the bronze bearings (or so I recall). The new bumper (JK-2394) is a better design and the tire carrier (5293) works very well.
I installed front and rear myself. Not difficult at all, except the directions aren't the best. My JK is a 2010, so I had to do some drilling to install the front bumper, as Jeep did a re-design for the 2010 / 2011 models.
Body Armor did tell me that there would be gas-can brackets available for the rear swing-out carrier sometime early next year.
Hope this helps.
Hope this helps.
The reason I bought these was because it was only $100.00 on Craigslist.
I haven't had the chance to touch them against any rocks, but when they do, I think it is going to be ugly.
So far they don't make any noise on the road or out in the trail, no squeaking. As mentioned above, they mount to the body, and it does support my weight as a step.
I would not be surprised if a big rock would dent them in to hit my jeep.
here's all my pictures for the rock rail:
http://s878.photobucket.com/albums/a...cpZZ1QQtppZZ16
JK-Forum Founder
blazer4949 has them and is now looking to replace them. apparently, because of the way they mount, they are susceptible to bending upward after a good hit. i would say that if you just do light to moderate wheeling, these will work fine for you but, if you play really hard, you may want to consider something else.
I really appreciate all the feedback. I see the Body Armor extreme mounts to the body as well. I wonder if those are stronger? I know a lot of guys swear by the LOD, EVO and Shrockworks. ORFab seem great too. Hard decision!
Like WOL said, if you do light wheeling, like not banging the sides of your JK that often, then you should be good to go. But just know that if you jeep rocks from left to right and hits a rock, it will bend and possibly injure your door.
JK-Forum Founder
i run the lod's but, pretty much anything that bolts up to the frame rails will do the job well. the only body mounted rocker guards i would recommend are the ones made by purejeep/hanson. they fully wrap around the rockers and bolt up clear through the body with crush sleeves as opposed to just using weak nutserts like other companies do. i have seen them take a beating well.
