On board water
#21
When we primaries camp we just use a couple 7 gallon Reliance "Aqua-Tainer" water containers.
We'll put one on top of our gear trailer and shower under it standing on a piece of plywood.
Also have a little propane hot shower system for when it's cold out. Came from Cabelas.
Short showers, but makes a big difference.
if you were part of an expedition team, one of the team jeeps could tow a water buffalo
225 Gallon 3,500 lb Water Pump Trailer Load Trail Trailer Manufacturing
#22
My plan now it to build a box in place of the rear storage compartment to hold the tank, pump, and hose for shower. That way everything is confined to one area. Also if I make it big enough it could house an on board air system.
#23
I did a write up a couple of yrs ago ...
https://www.jk-forum.com/forums/jk-w...-water-287963/
it was a pain to install but works great. First couple of yrs i just used a water jug and gravity flowed water thru the heater, but then finally plumbed in the rear bumper and a pump.
#24
I did a write up a couple of yrs ago ... https://www.jk-forum.com/forums/jk-w...-water-287963/ it was a pain to install but works great. First couple of yrs i just used a water jug and gravity flowed water thru the heater, but then finally plumbed in the rear bumper and a pump.
I have gotten in touch with someone to build be a box that the water tank with sit down in. I will be cutting out the floor where the storage compartment is in the back and relocating the exhaust so the planning stages are now done, now it's a matter of building and fabbing and buying everything to get it done. Can't wait to get it all in so I can start.
