On board water
I like the Frontrunner slanted tank Slanted Water Tank it holds 50 liters or 13.2 gallons of water. Hook a water pump up and you are good to go.
Alright I'm going to bring this thread back up to the top bc my idea is still in the works. I have found several different tanks and ideas. One idea is going to still consider mounting it up top on the roof rack but I'm thinking about the weight issue. I am considering using fresh water tank from a pop up camper which the one I found is 17 gallons. Also another idea I have going through my head is relocating the exhaust to be a shorty dump and then using a gas tank skid plate from a 1996 and below jeep Cherokee with a new plastic gas tank or a water tank of some sort mounted where the stock muffler was mounted. I already have a gas tank skid to do mock up from a previous Cherokee I owned.
Anyone have any suggestions or ideas to throw out there??
here a picture of the skid plate for reference. photo gotten from google but same thing.
also here I the Tank I was considering mounting to the roof rack. its slim and would distribute the weight well.
Pop Up camper 17 5 Gallon Fresh Water Tank C R | eBay
Just a consideration: My experience is that as you build a Jeep for extended travel the bulk of the weight ends up on the rear axle. Storage drawers, refrigerators, tools, water jugs, food, extra gas, Hi-Lift, etc all end up back there. The rear will sag and you'll be soon running around on your bumpstops. Whenever you get a chance to shift some weight forward (not upward), it's a good idea to consider it.
I use my stock rear bumper in conjunction with a pump and heat exchanger plumbed into the engine cooling system and it gives me ~7 gal water at any temp i want in 5 min or less. Not for drinking but great for hot showers.
I like the idea of mounting a tank lower rather than on the roof. 125lbs on the roof would be pretty noticeable even around town. If you do end up with a roof tank, you might want to think about uv exposure. White poly, like the 17 gal ebay tank you referenced, will degrade and crack with constant sunlight exposure. You could keep it covered or use a colored uv resistant tank.
do you have any info of how you did your heat exchanger In with the engine cooling system. I'm thinking of doing the same thing if I mount it below.
When we dispersed camp we just use a couple 7 gallon Reliance "Aqua-Tainer" water containers.
We'll put one on top of our gear trailer and shower under it standing on a piece of plywood.
Also have a little propane hot shower system for when it's cold out. Came from Cabelas. Short showers, but makes a big difference.
