On-Board Air Mounts???? Where???
Old 10-16-2012, 05:01 PM
  #51
powrsurg's Avatar
I came across this last night. Its a great option for a clean install but its not cheap.
JK Side MPAC Rack
Old 10-29-2012, 10:54 PM
  #52
Toro34's Avatar
Originally Posted by GJeep
Got the ARB CKMTP12 portable compressor.
It's the same twin-head ARB compressor as in the post above,
but packed together with a 4 liter tank and all needed accessories
in a tough portable case.
150psi and good flow. Inflates fast and good for pneumatic tools.
Eliminates the mounting question...
I'm going to install a socket at the trunk, leading directly to the battery
(thick wires), so the compressor will be used from where it is at the rear,
no need to open the hood.
Attachment 378849 Attachment 378850
Have you looked into the Warn Quick Connect cables and plugs? That may be just the ticket. I plan to add them to whatever aftermarket bumper I end up with
Old 10-29-2012, 11:08 PM
  #53
emtclimbermatt's Avatar
Originally Posted by GKR
Replaced my Warn SPI with the dual ARB. 2 Gallon tank. Faster, quieter, higher peak pressure and takes up less space.
is that a home made Tank bracket? and how big is that tank?
Old 10-29-2012, 11:32 PM
  #54
FlameRedJK's Avatar
Just got the Dominion Offroad setup installed courtesy of Woods...I'm pretty pleased with it so far, it does what it is supposed to do.
Quick Reply: On-Board Air Mounts???? Where???
