Black Diamond 2" BB - Swaybar Question
Calling on advise from the lift Gods/ I installed the BD 2" BB a month ago. I am installing shocks tomorrow. When I installed the lift, I left the factory coil isolator in place to even up the front end rake, so effectively a 3" lift on front and 2" on rear.
Question is: Do I have to get extended swaybar links for the front because of the 3"? or am I only being limited by 1" in articulation if I keep the stock links on? First and foremost, I dont want to cause any damage to my unit.
Thing rides wonderful, and I dont want to throw money at something without need.
Thanks.
Thanks.
any time i offroad i disconnect my front swaybar. if you do that then you dont have to worry about it limiting your flex. you are not going to cause any damage by keeping the links that you have. just get a set od quick disconnects and your current links will be fine.
If you disconnect you will be fine, if you don't you may overextend the swaybar and it will rotate frontward and break....don't ask how I know this....I ended up getting Currie rear adjustables and moving my rears to the front.....now I have TeraFlex discos on the front.
I have the rough country 2.5 bb. I stopped in at the 4wdparts store in Coppell, TX and asked that same question - they claimed I did not need the extended sway arms, assuming I did disconnect when flexing. I still think I will try to pick up a pair as their is quite an angle on the front links. I hear the stock rears will line the front up almost perfect after a 2.5/3" lift.
ps. I have a Rubi so disconnects are a non issue.
RB
RB
RB
RB
What is the store name in Coppell ? I would like to move the rears forward, and do the adjustable on the rear like you did. What did they cost you? Do they have a recommended length for a 2" rear lift?
