Bilstein 5160s........
Hey guys need some help. Im bout to install a Teraflex 1.5 performance leveling kit on my 10 Unlimited Sport. Question is can I run the Bilstein 5160 on the front and back. I know the front is for 1.5-3 inches of lift,but the back ones say for jeep with 2 inches of lift. Now the leveling kit lifts the rear 1 inch. Is that going to be a problem for the shocks in the rear?
1 Post
Hey man, I just purchased a Teraflex 1.5" performance leveling kit (coils) for my 2010 2-door Sport. I went with OME shocks, I've had these before and really liked them. After explaining the situation Northridge sent me # N196 and N198. I trust Northridge but have seen websites describe these being for a 2 inch lift so I sort of share your concern.
Haven't installed yet, this will be a major job for me...
Let's keep each other informed.
if i was paying regular price i wouldnt get them. A guy i know said they fell off the back of a truck somewhere. Couldnt let an early Christmas gift pass me by. lol
1 Post
OK, I got the Teraflex 1.5 Performance Leveling Kit mounted with Old Man Emu shocks. The ride is much like stock but a little bit firmer, which is what I wanted.
No problems with the shocks on the road.
Off road with full articulation remains to be tested.
1 Post
Hi Karl
I would love to help you, but measuring is kind of hard. I live in the hills and it's very hard to find a level piece of ground on the streets around the neighborhood. Also I don't have an inch tape measure ... stupid foreigner
Anyway, I was using the stock coils for a 2010 2-door JK Sport hardtop auto, no tow package or anything like that. This would probably be one of the weakest coils, I imagine. As you know I switched to the Teraflex 1.5" 2-door coils, actually more like 2" front and 1" rear. They are longer but also a little stiffer and hopefully better able to take sag, once I get my ARB bumper mounted.
From center wheel to bottom lip of wheelwell (the real bottom, which is a little lower than the visible curve) is:
left front: 57,5 cm which is 22.64 inch
left rear: 52 cm which is 20.47 inch
right front: 55,5 cm which is 21.85 inch
right rear: 54 cm which is 21.26 inch
You need to average that a bit since obviously I wasn't level. Also I don't have measurements from when it was new with the stock coils.
So there you go, hope it helps.
Bilstein 5160 BR5-G720-H0 (Also called 25-187663,or the 2" Rear) Collapsed: 14.92 Extended: 25.0 Travel: 10.1"
Stock Rubicon Collapsed: 14.69" Extended: 22.56" Travel: 7.9"
