Bike Racks
Old 08-13-2007, 03:52 AM
Mark Doiron's Avatar
Originally Posted by KMHENRY77
I will take my spare off and see if the cap pops out, from the outside the cap is in so tight it starts to raise the metal on the wheel when I try to pry it out.
It better pop out, because this is exactly how the Mopar bike rack attaches to the JK.
Old 08-13-2007, 05:24 AM
priell3's Avatar
I love my Mopar spare tire bike rack. Holds two bikes securely, even when you leave the pavement. I had it on my Liberty, it is now on my JK. I bought it at jparts.com.
The center cap is easy to pop out from the back side once you remove the spare.
Old 08-13-2007, 05:34 AM
fullbore's Avatar
Hello everybody,
I need to mount a bike rack on my Rubi Unlimited for my vacation and I can't seem to find anyone that knows what racks will fit. I thought about using a Thule spare tire mount but it shows you need a wheel with an open center and the Rubi has some sort of Jeep logo cap in the center of the wheel. Does anyone know if you can take out the cap? Or if not what hitch type rack will give enough room so the bikes will fit in them with the spare tire mounted on the tailgate. None of the ones I have seen appear to stick out far enough to miss the spare tire?
I am looking at carrying 2 bikes in case that makes a difference.
I've had a 4-bike Thule hitch-mounted rack for 5 years that I've used on my Trooper and now JK that works great. I bought it 5 years ago so my exact model is probably discontinued (it has a cable lock integrated into the frame).
Old 08-13-2007, 07:37 AM
redWRANGLER's Avatar
Here's my Thule rack with a hitch extension. It holds 4 bikes and swings out on the same angle as the rear door. Works great, had it for 4 years on another truck.
I have 33's.
The hitch extension adds a little wobble which I don't like. Haven't figured out a good way to remedy it, any ideas?
[IMG][/IMG]
[IMG][/IMG]
Old 09-17-2007, 10:03 AM
nader's Avatar
Originally Posted by jeepdave
I'll second the Saris T-Rax is the only hitch mount that will clear my rubicon's factory spare. We'll see if that is still true after I put my 35"s on.
I tried the saris, thule and yakima hitch mounts and they all hit the stock 32" spare tire. What do you do if you have a 35" spare?
Also the hitch mount carriers that I checked out specifcally say not to use any sort of extender. Not sure why though. Also checked out the Moapr one and it says not for Rubicon. Porbably becuase of the larger tire.
Old 04-22-2008, 01:35 PM
MikeNapes's Avatar
I just installed the Thule 964 Revolver on my '08 Wrangler Unlimited (4-door) Sahara.
I was concerned about the "fit" from all the posts about racks not clearing the spare tire, but this rack fits PERFECTLY...without any hitch extensions.
I visited a local bike store to talk about racks that would fit a Wrangler (actually was interested in the Saris T-Rax Pro and Thule 964 Revolver before walking in there) and they happened to have the Thule 964 displayed and put together already. I figured we'd solve this "does it fit on a Wrangler or not" problem real quick, so I asked the guy to bring it outside and slide it into my hitch receiver to check it out.
We slid it in, lined it up and tightened it up and it fit perfectly. Problem solved.
It clears the stock 18" spare AND you can lower/raise the two bars that the bikes sit on down (in its folded position) and back up again (in its "bike holding" position) without making contact with the spare tire. In it's up position and when it's tighted to the hitch receiver, you have clearance about the size of the thickness of a pencil between the tire and the closest part of the rack.
Yes, this rack is pricey at around $400...but I decided on it and against the Saris because...1) I now had first-hand evidence that the Thule 964 fit my Jeep Wrangler, 2) I've owned other Thule racks and I know they're solid and have a good reputation...I actually know nothing about Saris and would have been taking a leap of faith in the area of quality/build, etc.. The Thule is solid with very little "give", 3) I ski in the winter, so I left open the option of adding on a ski/snowboard rack (to the bike rack) when the time comes, whereas Saris doesn't offer an add-on/attachment like that, 4) the swingout feature on the Thule is optimal for me and my family of 4...I know there will be times where my wife, kids and I will be driving somewhere to go bike riding and we'll need to stop somewhere, for some reason, and someone will need to get something out of the back and we'll be able to easily access the cargo area without having to remove the bikes, 5) the Saris sticks out an extra 5-6" from the receiver, which is good because it will give you MORE clearance from your spare tire if you need it, but I ultimately looked at that as a negative because I want my rack to be optimal on other vehicles too. For example, my wife drives a Toyota Sienna minivan...and if she ever wanted to go bike riding with or without the kids and knew she wouldn't have access to my Jeep, the Saris would (appear to) be sticking out sooo much further on a non-Jeep vehicle because of that extra clearance. It would still function just fine, but that was more of an aesthetic concern for me, 6) it fits!
That's it. I wanted to post this and help anyone out there who is on the same quest that I was just on.
Quick Reply: Bike Racks
