Big tires+Supercharger, No Gears
Hi,
I am planing on running the below on my 2DR M6 JK
-Hesco supercharger
-34s
-2.5 Coil lift
-stock 3.73
i think it should be fine over all with no need to change gears.
How do you think it will perform with stock 3.73s? will it be more sluggish than stock at low end till boost is generated?
-Hesco supercharger
-34s
-2.5 Coil lift
-stock 3.73
Ahhh....the age old debate, power or gearing......or as in your case both. I have had some experience in this with some past vehicles so i will be blunt and honest with you. You should use both. Bottom line is either the supercharger or lower (numericaly higher) gears will solve your problem of low power, but to minimize the stress on the rest of your drivetrain, keep your speedo and sensors happy, keep your rpm's in normal range, etc. you should gear appropriatley for the 34's (around 4.07-4.10). That keeps everything in the jp happy before adding the bennifit of extra power, it also alows the stock computer to work appropriatley with Hesco'a piggyback.
Before you plunk cash on Hesco .... At least take 5 minutes and comparison shop the Ripp SC !!! https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/ripp-supercharger-kit-pics-vids-44282/
Sponsoring Manufacturer
Hi,
-Hesco supercharger
-34s
-2.5 Coil lift
-stock 3.73
-Hesco supercharger
-34s
-2.5 Coil lift
-stock 3.73
Furthermore using 3:73 gearing will only deliver less overall WHP as you are putting added stress on the transmission (and the tran ECU) and it will more likely slip the converter and power. So in our opinion we recommend looking into proper gearing (5:13's), a trans correction tool (Hypertec) and supercharger and you'll have a lot more fun, put down more power and most importantly keep things safe
Questions always welcome,
RIPPTECH
