Big step
Big step
Okay. Soon I am looking to purchase a 6" suspension lift or my 2008 jk. Also I would get 37" tires. I have been saving for this buy and have well enough $. For extra necessities too. What else would I need? In regards to spacers? Gears? Axle? Fenders? Etc.
Bone stock right
Now
Bone stock right
Now
You're going to need gears. You're going to need axles. You're going to need drive shafts. You're going to need a premium lift kit, complete with track bars, adjustable control arms, etc.
You're going to need to ask yourself why you really want a 6" lift when you can fit 37s on a lift half that size, have a lower COG and outfit it with premium parts for less dollars.
Nevermind reread, add a CAI, Catback exhaust and a superchips setup to maintain if not gain a Low end torque and HP that way you can also tune it for your application (ie: on-road/off-road)
I would do a 4" lift with flat or cut fenders, adjustable front lower and rear upper control arms, front driveshaft, gusset the d-30, extend brakelines and bumpstops at a minimum. You will want to re-gear but you didn't specify auto or 6 speed
It is an auto. And the reason I wanted to go with the 6 inch. Was just strictly because I wanted it to be BIG. I know there will be several other parts needed for such a lift and I'm aware. Some say gussets/sleeves. Should I take this route? Or go straight for the bigger axle
The axles are not the problem it's the lift , the higher you go the more you are going to change all the drive line and supsesion parts , you will have to beef up the axle for 37's but the most of the work would be the suspension
