Big Difference between RC 2.5 coil and budget?
Anyone know any differences between the two kits? I have the spacer lift and want to know how much better (if any) the coil lift is....Ohhhh I have no issues with the spacer lift...Just thinking about a new bumper and want to keep it around the same height...
Keep in mind, the lift kit is only shocks and springs. I also added JKS track bars and sway bar disconnects. If you get the JKS sway bar disconnects, get the longer ones. David at Northridge suggested the <2" version, but the >2" version would have been better. I'm maxed out on the length adjustment and it just barely levels out the sway bar.
As far as sag goes, I do have a little bit of sag in the rear, where the Expedition One bumper/tire carrier is. The JK looks good, though, as it should have come from Jeep.
