BFG Mud Terrains - What to expect?
still using my stock 2012 rubi tires. dont really have any complaints. they work well wet or dry and in the snow as well. Got about 9 k on them so far and they still have a ton of tread left and most of my driving is up and down the highway.
Perhaps there's a drastic difference between the KM2 and the KM? I'm running KM2s (35x12.50x17), I have 20,000 miles on them and they look nearly new.
On the topic of how they do in assorted conditions (KM2)...
Rocks - great
Mud - great
Sand - great
Snow - great
Rain - poor - give yourself plenty of room to stop.
Ice - terrible
EDIT - I do a 5 tire rotation every time I change the oil.
Rocks - great
Mud - great
Sand - great
Snow - great
Ice - terrible
I'm still running my 12 JKU Rubicon on the orig 255 75 KM's. It's ridiculous I have a little over 70k miles on them and they're still not done. I quit rotating them at about 60k and they are pretty badly cupped and noisy now, but still quite a bit of tread. Most of my mileage has been on the interstate but the KM's worked pretty good other than snow & ice. I've never had tires last anywhere near this long, especially not an aggressive tread like these.
Rocks - great
Mud - great
Sand - great
Snow - great
Ice - terrible
Rocks - great
Mud - great
Sand - great
Snow - great
Ice - terrible
They'll get the job done. My Rubi take-offs had <4,000 miles on them when I picked them up, and they've seen all kinds of terrain. They're great on mud, rocks and sugar sand, as you might expect. In my experience, they do just fine on wet pavement and on snow/ice, too, as long as you drive carefully.
Be prepared for balancing issues and uneven wear, even when well cared for and rotated every 3- to 5,000 miles. Mine are on track to need replacement by January or February, and they'll have had about a 30,000-mile lifespan.
They're fine stop-gap tires until you can afford to go bigger, but I wouldn't plan on them being my final tire choice. I'm planning to replace mine with a set of 33-inch Duratracs, as a step-up plan to eventually running 35-inch KM2s. (or KM3s, depending on their launch date)
They aren't dangerous, per se, but they don't have the siping to give them great performance on water and ice. The more siping a tire has (to a point), the better they will perform in wet/ice conditions. That same siping is what will cause a tire to chunk in rocky conditions. It comes to what balance you want.
That said, I have been through many rains and winters with them and do not feel endangered. If I can do that with my sometimes stupid right foot and 400 HP then I doubt they are dangerous. If left on, the traction control will not let you get too out of sorts anyway. Just be aware that you cannot hang curves on slick pavement as fast as you might with a sticky rubber, less aggressive, siped tire. Unless you like to slide around now and then on purpose, that is
They have no sipes to grip, just big flat blocks of rubber. So by design they are not going to be great on slippery stuff. You can have them siped at a tire shop as I did my first set and that will help a little.
