Best skid plate setup ?
I've never used or had any experience with smittybilt, and I've heard both good and bad reviews (probably more bad,) but Qtec has a special that they'll give you a free evap skid plate with the purchase of the smittybilt engine, transmission, and transfer case skid plate purchase. I think it's like $350 shipped.
Maybe someone that has it will chime in with experience.
The only skids I added to my Rubicon is an AEV rear diff slider, home made weld on lower control arm skids, a Poison Spyder crossmember and diff covers (which only the rear rubs with a Teraflex drop bracket. I ground a little off the tracbar and it clears now), and Im not sure what Im going to use for an engine/trans skid as of yet. Theres just too many on the market to choose from. I havent hit my EVAP yet, but skids have gone down in price for that so I might just get a Qtec one. They all look the same anyways so why spend big bucks on it.
Synergy Manufacturing HD Skid Plate System for 12-16 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
Synergy Manufacturing 5714-BK - Synergy Manufacturing Gas Tank Skid Plate for 07-16 Jeep® Wrangler Unlimited JK 4 Door - Quadratec
here is what I did you will probably need to have a shop do the gas tank.
I chose this because of what I read on the forum that Steel was the way to go as aluminum will bend to easy.
If it is genuine grade 8 hardware you're going to have a tough time damaging the bolt head, but it is not impossible. But even with the chinese steel and powdercoating, $300 for an oil pan / transmission / t-case / evap skid is a screaming deal.
Rock Hard skid plates are what a few of my local club's members use.
yeh mine is really surface rust
no damage , wonder what it looks like on top side though ? rust restorer and then hit it with flex seal i think for mine . Otherwise it seams to just rust again ( hate rust ) aluminum might not be as rigid but it wouldnt turn to rust. Like you said (why add weight ) over the factory one and have both end up rusty in a year or so . id rather replace than cover
