Best short arm kit
#21
The one thing that has me skeptical of MC kit's as a whole is the complicated bends of their track bars. Having bent 2 trackbars now, I wouldn't settle for anything with large and/or complicated bends, and I wouldn't settle for anything less than solid bar stock. No tube.
Their joints have been getting great reviews from solid users I would personally trust to be truthful and unbiased. I have no personal experiance... I've run an assorted combination of heims, clevite joints, and JJ's and have only had issues with clevites eventually wearing.
The think with any bolt on kit is you're not going to get any better than factory geometry. So, with that said, get the kit with strongest arms, most reliable joints, and the ride you are looking for. That's the best, most unopinionated advice I can give.
Lol fair enough. I agree on the track bar. I won there bracket and its a 6.5" raise in the rear! Its obsurd. It allowed me to make a 1.5od x 1/4 wall track bar STRAIGHT across, no need for all the stupic bends. Id rather have the rear trackbar bracket match the lift height though also... Not be different from the front. Half the people posting reviews are people who have just read what they typed. As I said im sure there fine, but not for me. Also they dont make them in the length i need id have to make them work fabbing them myself anyway, not worth it. IMO you want a better ride in a 2 door stretch it, on a 4 door not much will be noticable, but maybe im just not picky enough...
#22
Almost all bolt on kits are the same with the end joints being the real difference. Some of the arms are bent for more clearance or run a thicker tube but in the end they are all pretty capable and while everyone is obsessed with the "best Kit" and the ride of the MC joints they will totally ignore geometry in the suspension and steering. MC joint's are nice and do ride good, a Johnny Joint is not a rough riding joint and does have a rubber type isolator as well as ballistic and the new Rock Krawler joints. They are a spherical ball but are not a metal on metal joint like a Heim joint is. These forums are funny on how they are just a marketing tool for the manufacturers. When I first joined it everybody was all teraflex, then it was rock krawler, now metal cloak is all the rage and is the must go to kit. Find a kit that does what you need it to do and pick the one that fits your budget. If you can't afford a full kit do a budget boost or built it slow over time and just expect it to be a bit rough and improve over time. People out there that tout that MC is so much better then Rock Krawler and that it is the absolutely best kit you can buy and you will so much better at wheeling with that kit is just justifying to themselves spending the money.
#23
Almost all bolt kits are the same with the end joints being the real difference. Some of the arms are bent for more clearance or run a thicker tube but in the end they are all pretty capable and while everyone is obsessed with the "best Kit" and the ride of the MC joints they will totally ignore geometry in the suspension and steering. MC joint's are nice and do ride good, a Johnny Joint is not a rough riding joint and does have a rubber type isolator as well as ballistic and the new Rock Krawler joints. They are a spherical ball but are not a metal on metal joint like a Heim joint is. These forums are funny on how they are just a marketing tool for the manufacturers. When I first joined it everybody was all teraflex, then it was rock krawler, now metal cloak is all the rage and is the must go to kit. Find a kit that does what you need it to do and pick the one that fits your budget. If you can't afford a full kit do a budget boost or built it slow over time and just expect it to be a bit rough and improve over time. People out there that tout that MC is so much better then Rock Krawler and that it is the absolutely best kit you can buy and you will so much better at wheeling with that kit is just justifying to themselves spending the money.
Very well said sir
#24
#25
What is the best short arm lift kit.I just traded in my 09 rubicon for a 14 I ran a o.m.e 2.5 with 35 km2. This time around I am looking to do a full suspension with all the links the. The 2.5 wasn't enough hight the underneath of my Jeep got hammered from the rocks. I think I want to go 4 in I kept my 35s was considering the Currie Rock jock kit with maybee fox shocks
Handling is very good on & off road (including sprints).
The joints work well and silently, after quite a lot of offroading.
I think that Metal Cloak is even better, because of the dual rate coils and more travel -- with either their own 6Pack shocks, or Fox.
#26
Since the subject of geometry has been brought up a couple times, I would be interested in someone explaining how a complete MC kit has poor geometry, especially as compared to any other kits available.
I say complete kit because I don't think we can have a level discussion if you are talking about taking an individual component of kit A and mixing it with kit B from another manufacturer.
#27
#28
Now i do know they drop the front shock mounts to help with there poor shock size, but no one can argue that this kit is set up to be used with there fenders. Its also said by MK themselves that there are many factors that would make people not use all there travel, another reason you should buy shocks off your specific set up (tire size/fenders/bumps and other variables)
Im not a complete expert by any means, and cant explain what having 6.5" rear trackbar raise and no front would do, or what 6.5" rear or even 3.5" front would do ride wise, but id have to believe it will effect the body roll and weight transfer quite a bit...
Also for people who have never seen a mk joint have a slight downfall, heres one that came up just today..Joint was barely used.
https://www.jk-forum.com/forums/modi...5/#post3782814
#29
You can see a whole thread about why, because of this, 2.5" lift with 37"s is 'MUCH' better than 4" lift on 35"s. I don't buy that this 1.5" difference in lift makes such a big difference.
My 4" lift handles very well, and others' 2.5" lift that I've driven were only marginally better.
I have decided on 35"s, as 37"s put more stress on things, would have required re-gearing, and would have an advantage over 35"s only in the most extreme offroading.
As I chose 35"s and wanted enough ground clearance and approach/departure angles, 4" lift was the obvious choice -- and a good one.
Theory aside, according to my driving experience, the actual handling difference between 2.5" and 4" bolt-on lifts is small, and a 4" lifted JKU -- with a properly tuned suspension -- handles nicely.
#30
Yes, a lift spoils geometry a bit. You can see a whole thread about why, because of this, 2.5" lift with 37"s is 'MUCH' better than 4" lift on 35"s. I don't but that this 1.5" difference in lift makes such a big difference. My 4" lift handles very well, and others' 2.5" lift that I've driven were marginally better. I have decided on 35"s, as 37"s put more stress on things, would have required re-gearing, and would have an advantage over 35"s only in the most extreme offroading. As I chose 35"s and wanted enough ground clearance and approach/departure angles, 4" lift was the obvious choice -- and a good one. Theory aside, according to my driving experience, the actual handling difference between 2.5" and 4" bolt-on lifts is small, and a 4" lifted JKU -- with a properly tuned suspension -- handles nicely.
