Best riding 3.5-4" lift spring
Old 03-18-2015 | 06:02 PM
Dlampe's Avatar
I have had AEV and Metal Cloak. Both are fantastic. I couldn't tell the difference but both are better than stock Rubi and any others I have had the privilege of test driving. . Best change I made was the Fox performance shocks from BDS valved to the JKU.
Old 03-18-2015 | 06:23 PM
Unforgivable's Avatar
What size lift and tires you running the the AEV?
Old 03-18-2015 | 07:16 PM
Dlampe's Avatar
I had the 3.5 lift with 35's. I currently have the 3.5 metal cloak. Ride is really about the same. I do like the Fox shocks over the Bilstiens.
Old 03-18-2015 | 08:21 PM
mds22's Avatar
I doubt you'll find better riding springs than the RK triple rate.
Old 03-21-2015 | 07:45 PM
Ivan Dan's Avatar
Originally Posted by Rock Krawler Suspension
Dan, How old is the kit on your jeep roughly?
RK
it was just installed less then a year ago but I don't think it has the triple rate springs. Can you tell?
Old 03-21-2015 | 08:31 PM
GoBig's Avatar
Anybody run the Currie 4" springs?
Old 03-21-2015 | 11:27 PM
rsbmg's Avatar
Pull your shocks off then go drive around, you might learn your shock valving is the culprit.
Old 03-21-2015 | 11:44 PM
rsbmg's Avatar
No but if you ask someone who does I will bet 10 bucks they say they are "the best riding spring ever" or "better than stock".
Old 03-23-2015 | 10:46 AM
Rock Krawler Suspension's Avatar
Former Vendor
Attachment 602434
If you had an order date for the kit we could tell by that! The front coils went from a progressive spring to a triple rate spring so the difference is very hard to tell visually. Are those the 2.5" kings you have in the jeep as well? Typically you will see those large kings being on the stiffer side.
RK
Old 03-23-2015 | 10:52 AM
DunnyBunny's Avatar
JK-Forum Ambassador
RK
I'll second the comment on the kings. I had them and almost immediately sold them and put my regular fox shocks back on.
Quick Reply: Best riding 3.5-4" lift spring
