Best quality most affordable 2.5" lift
I'm kinda torn between the Teraflex and Full-Traction kits... both are pretty complete but I'd have to buy either shocks or track bars and LCAs separate... I'm going to pull the trigger for an order as soon as I get paid, so any input would be really appreciated! I'll probably have to save up a bit more for the FT though, considering its cost PLUS buying some Bilsteins... gah so confused...
I did! Got the 3" OME LT kit with HD springs, JKS Lower Control Arms, teraflex SS and a slew of other gear. Had to majorly re-center my steering wheel but it rides sooo awesome. I need an alignment I think, and my tires need balancing, but I think after that it'll be perfect! I'm really really happy with it. It looks totally badass too! I'll have to get some pics. This stance is great with 35s, heck it even makes my tires look too small haha!
if u put the lift in you can align it yourself with simple tools and some time. u need a tape measure and a angle tool.. inclinmeter. found at depot or lowes in tool area by rulers and levels. follow the doit youself alignment writeup on project jk. u should not need to adj toe. center axles and steering and adjust your caster to about 5 degrees both wheels. thats where i'm at and it drives GREAT on highway! 85 no problem.
i have been fiddling with it and thats where i like it.. maybe mine is 4.7 also.. the dial angle tool i have isnt as accurate as a digi one, but the steering feels good and the wheel actually returns to center quickly now.
this is similar to the tool i am refering to..
there is NO way u can get 6 to 7 degrees with the lca's set to 23" eye to eye. mine are way past that. i got about 9 threads showing before jamnut. thats why after asking around i am going by what that angle tool says, not the measured length.. i might still bump it up more but i am nervous about the front shaft angle..
hope this all helps everyone.
https://www.jk-forum.com/forums/show...t=Rock+Krawler
