best overall and most affordable 2.5" lift for 4 door?
Old 08-16-2013 | 07:03 AM
AHunter's Avatar
Default best overall and most affordable 2.5" lift for 4 door?
Looking to get my first 2.5" lift for my 2011 Unlimited Sahara.
Will get 35's down the road but don't currently have them. No major off roading currently, mainly trails, logging roads etc...
looking to spend $200-$350. So many options of BB, coils, shocks etc... out there, curious to know who chose what and why?
Thanks for the input!
Old 08-16-2013 | 08:23 AM
not4mall_crawlin's Avatar
Most folks will say terraflex BB, but honestly all BB are the same... a spacer. If I go with one I'll prob go with the rough country - its like $178. I plan on holding out though and get a good spring lift ($1k range,) RK or other progressive rate spring. All depends on what you want to do with it I guess.
Old 08-16-2013 | 09:34 AM
Rita Wrangler's Avatar
I'm changing out my BB in a week or so... It's a Zone 2inch with shocks make me a offer
Old 08-16-2013 | 09:35 AM
SpicedCrusher's Avatar
I'd personally wait until you planned to slap the 35's on. It will look goofy with a 2.5" with 31's. Also if your only looking to spend a couple hundred that leaves you to the BB's. As already said there all pretty much the same and will give you a nice amount of lift.
Old 08-16-2013 | 09:38 AM
markymark_bc_71's Avatar
I would save just alittle bit more and get the Rough country 3.5" lift with shocks and springs for 500.00. I got it and it is great...
Old 08-16-2013 | 09:50 AM
nthinuf's Avatar
Spacers are fine, but it you plan on adding more weight (bumpers/armor/carrier/etc), new coils will handle it better.
No reason to spend money on new shocks if you are happy with the current ones, just get extensions. If you find that you start offroading more, then you can look into a better/longer shock.
Having the axles centered is a good thing, so look for a kit with decent relo brackets.
Swaybars will be angled down. Look for a kit that has new rear links, and you will move your stock rear links up front.
Brakelines will be stretched. You can unhook them to add a bit, or run to the hardware store and make some extension brackets, or find a kit that includes brackets.
Caster will be a bit lower, causing flightier handling. May not an issue at 2.5", but if you don't like the handling, you have several options to choose from. Just do some research before deciding.
Old 08-16-2013 | 01:36 PM
firecapt's Avatar
Check out "4WD". They have a section for lift kits less than $600. In it you will find some nice options for less than $300.
Old 08-16-2013 | 01:51 PM
firecapt's Avatar
Also check out "Auto Truck Toys" They have a nice " Rough Country Jeep Wrangler 2.5" Coil Spring Suspension Lift - JK " for $379.
Old 08-16-2013 | 02:03 PM
RND's Avatar
RND
Beat overall- OME with JKS arms, bars, brackets,etc..
Most affordable- all low end quality (Zone, BDS, Rough ((says it all)) Country, ProJunk)
Old 08-16-2013 | 02:18 PM
SBEII's Avatar
A vendor on this site is offering free shocks with rock krawler kits. Hard to beat.
Quick Reply: best overall and most affordable 2.5" lift for 4 door?
