best options to get rid of cam bolts
My jeep came with a 2inch mopar lift i have now put on a Rock Krawler 3.5 in max travel. What are my options in getting rid of the cam bolts. any one try using this product?
Tera Flex JK Front Cam-Bolt Washer Kit (4951700)
Let me know what you guys have done. The cam bolts keep shifting and messing with my castor setting on 4.5.
use weld washers , thats what i used . It's a thick washer with another washer that is a smaller size to fit into the hole that the cam bolt came from. The big and little washer is one piece
so you currently have cam bolts and want to fix the hole you knocked out for the cam bolts so you can run adjustable arms? If so, I would have a shop weld some 9/16ths ID washers to the control arm brackets. Shouldnt be more than 30 bucks or so if you bring the washers. Hell, if you were close enough, I'd tell you to stop by my house and I'd weld them up for you.
