Best option for my set up...recommendations? with nice pic.
#21
did you put bump stops on?? if so idk a couple of smacks with a big f'n hammer to get a little more clearance i have 35 with a 2"lift for the last 3 months and mine is no where close to it like 3" away and i adjusted my lowers as short as they would go.. hmm that just looks wrong IMO
#22
I would say NO!! Your list says you have 2 lower rear adjustable control arms. You need rear UPPER adj control arms as well! The good news is you only need to buy 2 arms(the uppers) With only lower adj contol arms you cant move the axle rearward. You can only adjust your pinion angle.
X2 Do What he said^^^^^^^^
#23
I only have 35's but I had the same problem with my Bushwacker flares. The flares stick out too far above the pinch seam that everyone trims. I was able trim the flare and use a heat gun and rubber hammer to reform the flare above the pinch seam. I also drilled an extra hole in that area and used a rivet to keep the flare from moving after I trimmed and reformed it.
Rob
Rob
