Best option for my set up...recommendations? with nice pic.
I think he's already trimmed. So get some adjustable rear arms move the axle back. Then if that don't work bump stops. I don't like bump stops because your negating the point of a long arm travel lift kit. So I would do the arms first
Mine is fully trimmed. The part that touches is the part I circled in the pic.
Yeah, I am trimmed. That pic isn't of my Jeep...just similar. Doesn't the Rock Krawler 3.5 mid arm flex system come with the rear arms that would push the axle further back or everything I need?
Not sure what that lift comes with in the way of control arms. One easy way to check is to look at your rear springs and see if they are angled forward or arched(They should be straight up and down). If they are arched, I would get adjustable control arms for the rear,, then have it aligned properly. Second to that, for a temp fix,, I would put in the coil spacers until I could afford the adj cont arms.
Okay, here is a better pic that shows exactly what I am talking about. Yellow arrow is the part that rubs. The red arrow shows the pinch seam trimmed. When I hit a bump and the shocks compress and travel, the plastic part that is circled rubs the tire and makes the crunch sound.
So, should I be able to move the axle back, or is that already done with the Rock Krawler 3.5 flex? If so, then would I just need an extra inch with body lift or just do the coil spring spacers?
Thanks for all the help guys...
Here is what the system is supposed to include:
System Includes:
(2) long travel progressive rate front coil springs
Double adjustable front track bar made from 1.5" solid alloy steel
(2) high clearance adjustable front lower control arms made of 1.625" solid alloy steel
Adjustable front sway bar disconnects
(2) long travel linear rear coil springs
Precision welded rear track bar relocation bracket made from thick laser cut steel
(2) high clearance adjustable rear lower control arms made of 1.625" solid alloy steel
Front and rear long travel stainless steel brake lines
Extended rear sway bar links, hardware and detailed instructions.
So, it seems as if I have everything in the kit to avoid the rub including the rear control arms, right?
Well, I just checked, and the springs look just maybe slightly arched a little...hard to tell really.
System Includes:
System Includes:
