Best lift and what makes it the best
#92
Originally Posted by icerk
Ok.. Thanks for info... Much appreciated...
#93
I have been going through the same conundrum. What lift to get. I am in a very similar position as well. I want to remain in the 2.5 range because I'd rather not re-shaft and I ultimately need to park in a garage. I have narrowed it down between the Teraflex 2.5 and the RockKrawler 2.5. It appears you can start with both coil kits and upgrade with the full arms at a later date or jump right into them. After joking about 100 different Jeep forums these 2 companies seem to be heavily favored from quality to customer service. I'm trying to keep major modifications out of the equation I don't really want to weld or drill into the frame which both seem pretty minimally evasive. Still not 100% sure which I'll go with but it's between these two manufactures.
#94
I have been flip flopping on shock choice but in the end the service teraflex provided me so far has sealed the deal.
#95
I was leaning toward this one until iread this post http://northridge4x4.com/proddetail....OME-JK_LT_LIFT now im not so sure i want a 2.5" or 3" that rides good on the hyway but i go off road a lot i mean like every day a lot so it needs to flex . i dont want springs that or going to sag or colapse after a few months i'm not crazy about the idea of having to rebuild control arm joints every year or so pluss some i have seen are noisy as hell on the trail. i've looked at RK and i realy like the EVO kit but kinda pricey i think i'l keep reading and doing more research
#96
For those on a budget what it the most complete suspension lift for lets say under $1500(including shocks)?
I really don't plan on lifting my ordered 2d Jk for a while but I have started researching and I am leaning toward Full Traction. Is there a reason FT is not in this discussion(with only one mention that I saw)? Is there a big difference between the FT economy + 3" and FT zero maintenance srs 3" lifts?
#97
I have the TF 2.5 kit with coils and shocks and works great and fits my 35's and best thing I did not have to replace my drive shaft. Good luck trying to park in a parking garage though...
#98
I did some semi serious wheeling for the first time this weekend and can see my current Jeep limitations as is. I am thinking of a 2&1/2 to 3" lift. I want to be able to run 35's but I need to fit in a parking garage and I won't want to have to purchase new driveshafts.
If you could but any lift regardless of price what would you buy and what makes a good lift good. Seems like the more expensive lifts that I have looked at seem to have better shocks and extra control arms or some gadgets I am not familiar with.
Sorry for the one more lift thread but I don't think I have seen anything that addresses some the additional items that come with some of the more expensive lifts and if they are worth the money on this size of a lift. Thanks.
Wants 35s Wants to be able to park in the Garage
DOESN'T Want to change Drive Shafts
There are some incredibly intelligent people that have serious skill and knowledge on the subject. So if I offend anyone that is not my intent.
WAY OVER THINKING!!!!!!!
There were a couple of great comments
Wayoflife
Nobody that spends large amounts of money is willing to admit they made a mistake (except the one guy) (rare indeed)
Check out others rides and see if you like the feel.
And the best suggestion
Do it in stages!!!!
I have 52k on my jeep about 20k of it trails. I put the TF 2.5” at about the 2k mark. I was an early adopter not nearly as many choices as now or knowledge.
The only MOD I have done to this lift is the 9/16th bolt on the Steering Stabilizer (cured DW instantly)
It still rides great and has been very low maintenance and for the wheeling I do. It works
Don’t make it about the money. Make the decision that works best for your situation.
Riding the trails with your friends is the most fun you can have on 4 wheels (sometimes 3 or 2 depending on the situation)
My opinion
#99
I am in the boat of looking for the most complete kit, with adjustable arms and track bar. I want to do this once. I am not into doing it in stages, which may be the better way to do it. It's just not for me.
#100
