Best Leveling Kit
Originally Posted by TheDirtman
The JKS acos is the best leveling kit out there hands down. You can level it out perfect and add height in the future if you need to, up to 3.5"
You asked for the best here it is. Any other spacer is just a piece of plastic stacked on top of your springs.
http://store.jksmfg.com/merchant2/me...de=Coil_Spring
He makes a good point. If you're planning on going bigger in the future, I'd go with spacers. But, if you plan on keeping the leveling kit for a while, I'd suggest going with the TeraFlex coil leveling kit. I just put one on my 2 door this past week, and it looks really nice with 33s and rides great too!
cadenajeepjk (02-24-2023)
Well I appreciate all the help guys. I knew TeraFlex would be heavily favored here and nothing wrong with that. From everything I've read they seem to make some great products.
I'm still trying to decide on how long I'll keep it on. I want 35s, but don't know that I can justify the cost of rims, tires, lift all at once. I don't trail ride a lot (maybe once every 3 or 4 months). It's mainly a DD and beach cruiser.
(I also eventually added flat fenders for room for 35's.)
Originally Posted by Merlin4979
Why not just pick up a set of 4-door Rubicon springs from someone here on the forum, and then add the spacer Leveling Kit pucks? That's what I did. Cheaper than both leveling kits, and pretty much the same height.
It should definitely give you some lift. With you having a 2-door X, the 4 door Rubi springs should be taller and stiffer to support the extra weight. I wasn't exactly looking for a set, but happened to fall into a good deal on some from a local Jeeper who was replacing his suspension at the time.
