Best JK gearing change with 35" tires: 4.88 or 5.13 or stock
Old 01-17-2011, 02:30 PM
nthinuf's Avatar
Originally Posted by mjm
Why is this?? I have run into the same thing when calling around, most shops advise to go with 5.13's and not 5.38's. The shops I'm calling are very reputable and deal with JK's all the time.
Just because they 'deal' with JK's all the time doesn't mean that they really have a grasp on the differences in the engine and transmissions. We don't have the old high output inline 6 or a transmission with gearing that is matched to the engine output. Look at the charts in that high altitude threads linked above and see what you come up with.
5.38's are at super high RPMs when you start runnin bigger and bigger tires. I run 3000 RPMs goin' 70 in 3rd gear.
You are running 40" tires. With this engine/transmission, you need a lot deeper axle gearing than 5.38 - it just isn't available. So, you are running OD Off to keep anything close to freeway speed.
If you choose to drop down to 5.13 or 4.88 to bring your od off rpm's down at freeway speeds, will you have the hp/torque to actually hold those speeds? Or will you be dropping down to second to get your rpm's back up over 3k so you can go 70?
Old 01-17-2011, 02:48 PM
Tuto's Avatar
I do not belief in those charts.
I would to see comments from someone that actually have the 5.38 gears and an Auto.
My 2010 Rubicon, Auto w/ 4.10 gears stock tires 32, at 70 mph is about 2300 rpms
The chart reads 2080 rpm w/ 4.10 32 tires and auto.
Old 01-17-2011, 02:53 PM
tslewisz's Avatar
Have you measured your tires?
Old 01-17-2011, 02:56 PM
TexasTim's Avatar
I'm not guessing I have auto trans 35s and 5:13s. It's the perfect combo.
Old 01-17-2011, 03:01 PM
Loadbreak's Avatar
I have an Auto and the above chart was spot on when I had my 29" stock tires and 3:73 gears, then with 33"s that measured 31.5" then w/ 35" tires then the upgrade to 5:13's. It was spot on every time.
Old 01-17-2011, 03:05 PM
mjm
mjm's Avatar
I totally hear ya and all that I have read about 5.38's makes total sence. It just gets frustrating when you go to the experts (local shops) and say I want 5.38's and they act like that it's a crazy request. You would think that the local shops would be very seasoned on the JK as it's been out since 2007.
Old 01-17-2011, 03:35 PM
nthinuf's Avatar
As noted above, the chart is using actual tire heights. Not the mfg's spec. And not what you think your tires measure.
My AT"s, that the mfg lists as 33.8, were 32" when under the front of my jeep. My MT's, that the mfg lists at 34.8, are 33.5" mounted and sitting under my jeep.
So the moral of the story is ---> go measure...
Old 01-17-2011, 04:07 PM
thrshr01's Avatar
I believe when you go above 5.13 and hit 5.38's the pinion gets smaller, making it weaker.
Old 01-17-2011, 04:30 PM
Anaya's Avatar
I'm running 5:13 with 35" tires auto at 70 MPH I'm turning about 2400. I think 5:13 are better than stock I like them but I also think 5:38 would be fine you would have room to go up on tire size if u wanted.
Old 01-17-2011, 04:50 PM
joe002's Avatar
I would to see comments from someone that actually have the 5.38 gears and an Auto...
With my auto, 5.38s and 35" BFG KM2s (which aren't really 35 inches), eyeballing the speedo and tach, and checking/adjusting with a spreadsheet...
55 - 2,000
60 - 2,190
65 - 2,370
70 - 2,550
FYI - my uncorrected eyeballs saw:
55 - 2,000
60 - 2,200
65 - 2,400
70 - 2,550
Quick Reply: Best JK gearing change with 35" tires: 4.88 or 5.13 or stock
