Best equipment/practices for airing down
#21
To save time, I screw on 3 Stauns, pre-set to 20 psi. (or all 4 if I want 20 psi)
When I want less than 20 psi, the 4th tire gets the Multi Choice Deflator.
When the 'Multi' has finished, the 3 others are already aired down most of the way.
The Multi is then used to finish the airing down of the other tires.
It's not clear in the picture, but the selected psi is visible though the cover, in this case it is set to 18 psi:
#22
I ordered a set of Staun deflators from 4 Wheel Parts and they do a good job. Well 3 of them do. The 4th came damaged, had a flat spot and can't rotate the knob to adjust the pressure. I spoke with customer service and emailed a photo. The short side of a long story is they will not replace the damaged one. I will never do business with then again !!!
#23
#24
I custom made a 4 in 1 hose assembly with gauge and ball valve to do all tires up and down. Works really well.
All the tires flow to one location where I can fill or release air from. I will get some photos and details of what I used and how I would do a couple things differently tomorrow as I am away from my jeep today. Jeepswag had one a little while back. There is a link below to a video that I just found. They were charging $90 for it and my bright self thought I would build one for half that. Ya was I wrong. $150 later I got it all done. I do like how it turned out though and works great. I can tell you that I just ordered staun auto tire deflators and will use those no for airing down but will use my 4 in 1 for airing up. To easy to just screw on four little fittings.
#25
Once you use RADs you'll never want anything else.
Rimrock Mountain Supply | Products
Attachment 418133
Attachment 418133
Plus, this would be good to do when you buy your wheels (before mounting). Otherwise, you'd have to have your tires un-mounted and mounted again.
#26
Sponsoring Manufacturer
Yes, you'll want to do it before you mount up tires.
#27
Spreading the flow to 4 tires doesn't increase the compressors' flow rate, so there's no time gain.
The overall pipe length of a 4-tire assembly is longer than a single pipe. Longer pipes means more resistance, which reduces the flow rate.
'T' connections create resistance, and reduce the flow rate yet more.
If we inflate one tire at a time, we connect and disconnect each of the 4 tires.
If we inflate the 4 tires at once, we still have to connect and disconnect each of the 4 tires, and then disconnect the harness itself, and re-assemble it again the next time...
I don't see any advantage.
I see only disadvantages, unnecessary complication, and more potential leak points.
Do I miss something ?
#28
The maximum air flow from the compressor is determined by the compressors' specs.
If we inflate one tire at a time, that's connecting and disconnecting 4 times.
If we inflate the 4 tires at once, we still have to connect and disconnect 4 times.
I don't see any advantage, I see only disadvantages. Do I miss something?
#30
Staun's, Best 70 bucks I've spent on the jeep. Screw them on and then walk over to newbie and work on convincing them that they really do want to air down. Have them set for 12#, used some blue Loctite to keep them there. If I want to go lower it's easy to finish up with my low pressure gauge.
