best driveshaft choice for 2 door with 3.5 lift
ordered the clayton 3.5 lift. will order rear shaft on monday. do i need the front now (6 speed) ? which brand is the best.
I threw on JE Reels and have been very happy with em. I Had Tom Woods on my TJ and was very happy with those too. Really just up to you, both are great. I ran my stock front drive line until I decided to just change it one day. I think I put over 6,000 miles on it with no problems. So, you should be fine without changing it for a while. It really depends on the the axle angle and how your off-roading.
I just installed a 3" FT with the same set up, 2-door, manuall. Will I need new driveshafts?
What's the real deal!! I don't want to have to spend money if its not needed.
I have a 2dr with a 3" FT Ultimate lift and need a new rear DS after 7000k miles. If you wheel it, you will eventually need one. If you stay on the street, maybe light trails you might be ok.
there is info @modified tech faq in the drive train axels n gears . where i bought my lift they recomended je both front and rear. you save 100$ if you order both for around 820 no tax or shipping or my other option get rear only for now ( called clayton they rec. woods around $460 free shipping:
