Best Direction on Rear Axle /Coilovers
Damn!!! This is some seriously good info!
I believe you have all convinced me that the rear coilovers, and a D60 is not worth getting!!!
Sounds like the consensus is stick with the rear coil springs, stock JK 44, upgrade the shafts, and go with a locker if I feel necessary...
And proceed to bow money elsewhere!!!! Lol...SLABS???
Cantilever is most likely even more. Especially seen as you have to typically get bypass with it to keep up with the cooling seen as they run alot smaller coilovers. Alot more moving parts but yes the coilovers are tucked away safely. Not much "simple" about cantilever other than theres a kit for one. No on else offers one.
I would call lockers necessary more so than much of the other things mentioned...
Lockers were the single biggest off-road performance related change that I made
Then you can hear about all the options for lockers
Matthew
I'm in the same boat, 37s, PR44 front, and in the market for a 60 rear. I tried approaching from all angles, and no matter how you slice it, its gonna cost a whole lot of upfront money to swap the rear to a Full float 60, even if you go with the Spicer ultimate 60. (you're gonna need the front axle as well, and new wheels). Running adapters up front temporarily isn't really an option because they'd require a 2.5" adapter to 8 lug on top of 3.5" backspaced wheels giving you 1.5" backspacing up front.
You're really just gonna have to wait and save ~13-14k at least, or if you have the time, and your jeep isn't your daily driver, you can build out junkyard axles.
"Different" backspacing isn't the issue. A TOTAL net backspacing of 1.5" up front is probably not a good idea.
It'll be on a 44--not a 60. I was going thru the possible scenario of just getting a rear 60, while keeping the front 44 with adapters until he could upgrade the front as well. My advice being to to just save and get both front and rear d60s at the same time instead of running 1.5" backspacing on D44 balljoints and unit bearings.
