The best "daily driver" lift
#31
![Brows](https://www.jk-forum.com/forums/images/smilies/brows.gif)
#32
im looking to buy an 2011 2 door,,, i want to run 40's,,
wayoflife,, what would you suggest i get to accomplish this,,it will be a daily driver but i also do a lot of offroading as well here in the midwest,, i realize ill need dana 60's, 5:38 gears,,,but i have no clue on what lift to get,,,any advise will be helpful
#33
sure, i've personally installed and run a teraflex 2.5", full-traction 3" ultimate lift, a teraflex 4" flex arm lift, OME HD lift, OME HD +40 lift, off road evolution short arm coil overs and off road evolution long arm kit with 14" coil overs. this is to say nothing of the various other lifts i have personally installed and tested on other jk's. having said all that, if you're only planning on running 33's, i would just install them can call it a day. sure, you will have some minor rubbing but not enough to really matter and, if you want to address them, simply install a leveling kit or 2.5" budget boost. both are cheap and will get the job done ![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
I've heard complaints about an ARB bumper + winch (like I'm installing this weekend) trashing factory coils.. I think that's the MAIN reason I'm looking at lifts.. I would be cool with just popping in a few spacers, but I think after adding a roof rack, rear bumper, etc.. I might be replacing my springs and shocks anyhow....
does that sound reasonable? or am I worried over nothing?
If I AM going to have to install new springs and shocks.. I'm mostly interested in ride quality... but if I can make room for 34 or 35 inch tires.. might as well do that at the same time.
I love trails.. and a little rock crawling is pretty cool.. but I'm not going to be taking the 'hard' way up the mountain simply to test my rig, and climb every boulder..... I'm more interested in the view from the top..... and getting there without my wife puking.
Any experience with adjustable shocks? are they worthless? or actually worth looking into?
#34
JK-Forum Founder
![crazyeyes](https://www.jk-forum.com/forums/images/smilies/crazyeyes.gif)
for as much lift as you're going to need and as big of a tire you plan on running, i think you need to talk to off road evolution and get one of their long arm kits with coil overs. their kit is specifically designed to work with 60's and even come with high clearance rear control arm mounts that can only work with this setup. talk to mel and let him know that i sent you
#35
JK-Forum Founder
Sounds like you're the man to talk to ![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
#36
Right on man.. I sure appriciate your help.. You help a lot of people on here.. takes a rare person to put aside that much time for others.. it's often thankless... So THANK YOU. ![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
I've got a rubi, so I'm already on them there rubi shocks.. probably wouldn't see much of a difference with performance in an EMU shock, right?
My plan is to install the bumper, and see how it sits.. I'll likely end up putting in some EMU HD OEM height springs and at least a front spacer...
Do you see anything wrong with only replacing the front springs until I get my back bumper?
#37
JK-Forum Founder
#38
because on a 2-door, the rear drive shaft is really short and at 3" of lift or more, it will sit at a much steeper angle. this will put the CV boots in a constant state of pinch and, over time, this will cause the boots to fail. once this happens, there will be nothing to keep the grease inside and subsequently, the bearings inside will fail. the answer to this problem is to install a double cardin u-joint style shaft but, in order to do this, you would need to install a set of adjustable rear upper control arms.
can someone enlighten me?
#40
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
So, you need some way of 'tilting' the axle enough to get the pinion lined up...
