The best "daily driver" lift
I am looking at putting on a 4.5 sa lift on my not yet arrived from the factory 4 door sahara. I have been told by several local off-roaders to go with a bds lift. I will spend 95% of my time on the road and want the ride to be as close to factory as possible. Is BDS a top choice? The only lift ive done in the past is a 4 inch pro comp lift and it was ok. Also, is there a huge difference between a 3 and 4.5 inch lift in regards to handling and steering? Let me know what you all think, thanks.
JK-Forum Founder
having said all that, the question you need to be asking yourself is what kind of budget do you have to work with. again, the more complete the kit the more it will cost and the taller you go, the more complete you really want it to be.
JK-Forum Founder
Sounds like they are just more familiar with BDS or they get a higher discount compared to other competitors.
Not a good idea to ask these questions from a company making money off you, unless you really trust them. You're better off researching on here and base your own opinions.
I drive 120 miles a day to get to and from work.
I have a 3 1/4" RC lift on my X. I am also running 35's. The ride is nice. It is as smooth as it was when it was stock. I hope you take all this info you are getting in this post seriously. These guy's know what they are talking about. I offroad more than I thought I ever would. I wish I had found this site before I purchased the lift. Good luck.
JK-Forum Founder
not surprised - most people get about 30,000 miles/48,000 km before they fail and less if they wheel their jeep. still haven't answered how you will be able to address it when it fails with the kit you have.
because on a 2-door, the rear drive shaft is really short and at 3" of lift or more, it will sit at a much steeper angle. this will put the CV boots in a constant state of pinch and, over time, this will cause the boots to fail. once this happens, there will be nothing to keep the grease inside and subsequently, the bearings inside will fail. the answer to this problem is to install a double cardin u-joint style shaft but, in order to do this, you would need to install a set of adjustable rear upper control arms.
