best bang for my buck?
When it comes to modifying your Jeep, gas mileage is only an issue when the mileage between gas stations is more than you can cover on one tank.
Gears for SURE. You will relieve some stress on the drivetrain as a whole unit and will probably get some mpgs back as well. Then get a programmer for a little extra boost and fix your speedo.
It will drive like a whole new jeep...mine did !!!!
Check out this link for more info..
https://www.jk-forum.com/forums/show...?82262-Gearing
I run 35's plan on going to 37's. Tow a camping trailer in summer which is near the max tow capacity of the jeep. Should I re-gear to 5.38's at a quoted price of $1600. Or should I take that $1600 and buy a quality chip or programmer, with a CAI and save some $. Maybe with the leftover $ I could put some towards a LOD rear bumper....finally. My guess is the most improvement in power gain is going to come from re-gearing. Any advice would be appreciated!
If you have the extra $$ just bolt on our supercharger and you will have an extra 100 hp at the wheels at your disposal, not to mention the 80-90ft/lbs of trq...
RIPPTECH
An auto with stock gears and big tires means constantly lugging the engine at all speeds, and constant downshifts out of O/D, which means much higher rpm's to maintain speed, which means mpg's in the toilet. Gearing back to a 'better than stock ratio' (I say better than stock because auto JK's are undergeared straight from the factory), will relieve the extra strain on the drivetrain, bring rpm's up into the range where this engine likes to operate, and let's you maintain speeds without all of the downshifts out of OD. The net effect is better performance and better mpg's, not screaming high rpm's and worse mpg's...
You should open the drivetrain faq's and plug some numbers in...
The only downside to 5.38's may be OD 'Off' rpm's when towing heavy loads. Find your od on rpm using the chart, then divide by .69 to get od off rpm.
