Best 4"+ lift if Money was no Object
#31
JK-Forum Founder
One more quick question? What are the top and bottom spring rates on the recommended 2.0 King Coilovers with 12" travel, like the ones that are on WOL's rig?...and is there any reason why the remote reservoir is preferred over the Piggyback other than price? I have a "short arm" kit with 37's and Clayton adjustable arms so I will be using the same shocks as WOL I'm assuming.
#32
LOL!! i seriously doubt that off road evolution will be telling anyone what the spring rates are after spending thousands of dollars to figure out what works t the best regarding remote reservoirs, i'll let evolution answer that. aside from that, you will be using the same setup as what i have and it should work great with the claton arms
#33
JK-Forum Founder
apologies, I didn't realize or consider the time and development in figuring out the spring rates alone. I guess that makes sense as to how they achieved the superb on and off road ride quality. I would keep it closely guarded as well considering the testing that went into dialing the system in. I'm not that familiar with coilovers and "baja racing insired setups" so forgive my nescient questions. How long did you wait in between having the front coilovers installed and the evolever in the rear?
#36
Hope I'm not going to need another one. Should be staying between 4 1/2" and 5" of lift.
#37
AiRock is a definite must if quality and control mean anything. You can keep all the stock geometry on the highway running 37" tires. And when you want to play off road, you press the up arrow and lift as high as you need. The left/right/forward/back tilt feature is nice too for putting weight where you need it.
My question is if AiRock would be that much better with a long arm suspension. I've seen the TerraFlex lately and liked the way it looked. My wife has finallly stopped bitching about the difficulty of getting in with the 4.5" lift and 35's (she sees how much better we do in comparison to vehicles closer to stock); but I think going to 37's would be a bit much for her (she has a bad knee) unless I went with the AiRock with it's entry mode. I guess what I'm wondering is do the AiRocks bags have sufficient travel to make a long arm system like the TerraFlex worthwhile?
#38
What would be the purpose of going with AEV/Nth Degree? What's left? Isn't their claim to fame a good ride due to their springs? Why not just buy the whole Clayton kit minus the springs and then go AiRock?
#39
JK-Forum Founder
another question. Is changing over to the coilovers going to effect my driveshaft angle enough to worry about a new driveshaft. I already had an aftermarket 1310 front driveshaft installed with the clayton arms and lift.
#40
There is also the steering geometry kit, the new track bar brackets (that are very heavy duty), a future stinger kit, and tie rod flip kit with the Nth kit. In the past it was very common to find AiRock owners running the Nth kit with the system.
