Bent a piece on my axle, help.
i hit a ditch and the suspension compressed so hard a bolt on one of the linkages(?) came up and sliced my oil filter....my first thought was oil pan but i guess i got lucky.Attachment 208498 tough guard my ass
Sponsoring Manufacturer
EVO MFG Representative
Yes the EVO Control Arm Skids will work with stock control arms or any aftermarket arms (all arms).
EVO..
Andrew is right, Dynatrac can get you the control arm mount to have welded on AND the control arm skids are the best $30 you'll spend to prevent it. EVO makes the best S***.
Just so we are clear. Yes this perticular JK (OP) will need to have a completely new control arm mount welded on. I was just stating that the EVO Control Arm Skids are intended to prevent this from happening. So after he replaces that control arm mount, that he look into installing the EVO Skids or making something similar so this does not happen again.
EVO..
EVO..
Im not sure what its called, but i can look down and see the exact bolt that lines up just enough to clip into the filter (if pushed hard enough). il post a pic when i get a chance.
Upper control arm bolt? Wow man...that's a lot of flex. How deep was that ditch haha??
I am here: http://maps.google.com/maps?ll=36.656195,-87.484229
